How to tighten steering belt?
Postby szyblaszczyk » Wed Dec 28, 2016 3:03 am
Hi! I know that it's quite popular problem and solving it's quite easy but I can't find tutorial how to tighten the steering belt step by step?
My Hyundai Coupe is Gen 3 (GK) 2002 1.6.
Am I right that I should loose one of the screws?
https://zapodaj.net/fe7522b5b0db0.jpg.html
But what next guys? Please explain because it's getting worse and worse with steering belt!
szyblaszczyk
Re: How to tighten steering belt?
Postby MJNewton » Wed Dec 28, 2016 4:54 pm
You need to loosen the bottom bolt and then the one right at the top (not shown in your photo - it is the one that clamps to the slider). Post another picture showing more of the pump if you like and I'll pinpoint the exact ones.
With both bolts loose you then need to pull the pump away from the engine to tension the belt before tightening the bolts again. A piece of wood can help provide the necessary tension by levering the pump.
MJNewton
Postby szyblaszczyk » Fri Dec 30, 2016 2:46 am
Hi again. I added 2 photos. I think that this plastic cover for engine make this impossible to solve this problem and I need suitable tool, am I right?
https://drive.google.com/open?id=0BzKPh ... HFTV2F2bUk
https://drive.google.com/open?id=0BzKPh ... mt2d1R2ZTg
However, the thing is that when I asked two times mechanic to help me to solve this problem he just make very tight on the screws and it was fine for couple of weeks! He didn't do anything with the pump etc.
Any idea what did he do exactly? What's important, I have problem only with ORANGE belt. That's the one which get loose after some time and which is loose now.
szyblaszczyk
Postby MJNewton » Fri Dec 30, 2016 11:29 am
Your bolt no. 3 in the first photo is the pivot point - so that needs loosening - and there'll be another bolt to loosen at the top that clamps the pump in place. Remove the plastic engine cover (four 10mm bolts) and you'll see the bolt you're after.
MJNewton
Postby szyblaszczyk » Thu Mar 09, 2017 7:28 pm
Hi again. I left it for the winter but spring is coming so I finally need to do it. I made loose two bolts after finally I got suitable tool :D so pump was loose also but I have no idea what to do next? Pulling out pump from the engine makes no effect at all. It's still too loose. I recorded short video to show where I'm stuck. Please help. Thanks!
Here is the video:
https://youtu.be/I8oU0tqU1FY
szyblaszczyk
Postby MJNewton » Thu Mar 09, 2017 8:23 pm
Hard to tell exactly what's going on since the engine cover is still in place but it looks like you've got the pump pivoting okay. Might the belt be too big and hence you're at the maximum extent of travel? The cover needs removing to be sure.
MJNewton
Postby szyblaszczyk » Fri Mar 10, 2017 7:51 am
Did I unscrew right bolts? Confirm please if I did the right thing.
For now I can't unscrew bolts from engine cover. Don't have suitable tool.
szyblaszczyk
Postby MJNewton » Fri Mar 10, 2017 10:42 am
Can't really tell given the poor visibility.
MJNewton
Postby szyblaszczyk » Wed Mar 29, 2017 4:17 pm
No problem! I asked mechanic and I need new belt.
Is this one will be okay? Ebay Item:390669959740
To confirm what I'm looking for:
The orange belt needs to be changed ASAP.
https://drive.google.com/open?id=0BzKPh ... WJVWTlSdms - here is the link to my Google drive to see it
szyblaszczyk
Postby Vanhool » Sat Apr 01, 2017 4:37 pm
You got no chance there's nobody here except mj and me
Go join www.hyundaicoupeownersclub.co.uk for help
Vanhool
Users browsing this forum: No registered users and 8 guests
