I noticed a bit of corrosion on the base of the sump pan which appears to be seeping oil very slightly . Now can you replace sump on a 2.0l Gen2 without taking the exhaust off ?
Thats ok if the nuts are in good condition but they look pretty corroded. Are they tied bolts in the manicat ? If not I would just cut them off and replace with stainless nuts/bolts
just had Donna's engine out, look behind the manicat, theres a bracket, undo the manifold from the block, then remove that bracket from the front of the block, the exhaust will drop down a few inches, then you will have room to remove the sump.
Related Threads
Hyundai Coupe Forum
209.5K posts
17.7K members
Since 2009
A forum community dedicated to Hyundai Coupe owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
