Auto problem!
Auto problem!
Postby AussieJohn » Sun Nov 20, 2011 5:54 pm
Are there any auto gurus out there? I have a 2006 model, under hard acceleration it bangs when changing from 2nd to 3rd. Was a bit low on fluid which helped a bit when topped up. Do these transmissions have bands to adjust? Any help welcome.
AussieJohn
Auto problem!
Postby thedupleman » Sun Nov 20, 2011 5:55 pm
Change the oil and try it
thedupleman
Re: Auto problem!
Postby AussieJohn » Sun Nov 20, 2011 9:39 pm
Thanks, I'll change it!
AussieJohn
Auto problem!
Postby thedupleman » Sun Nov 20, 2011 10:22 pm
Easiest and simplest.then it gets more complex
thedupleman
Re: Auto problem!
Postby Androo007 » Mon Nov 21, 2011 6:23 pm
Over the years every single autobox problem I've seen has been because of incorrect levels or overdue changes
Androo007
Re: Auto problem!
Postby AussieJohn » Mon Nov 21, 2011 10:20 pm
I am pinning my hopes on an oil change, is there a drain plug or do I remove the side panel? how much oil for a change? I guess some oil stays in the torque converter.
AussieJohn
Re: Auto problem!
Postby AussieJohn » Mon Jan 23, 2012 10:26 pm
Changed the oil ; the problem is now very bad. I'm having a low mileage auto box put in this week so hopefully then OK. Do these cars have auto problems regularly? if so I will sell up and buy a manual; advice please guys, cheers, John.
AussieJohn
Re: Auto problem!
Postby mnemonic » Mon Jan 23, 2012 11:45 pm
Sorry to hear that mate. The Hyundai autobox is not noramlly a problem if well looked after with regular changes etc - I have been involved with Hyundai since 2007, and the only problems have been from incorrect levels and dirty fluids.
mnemonic
Re: Auto problem!
Postby AussieJohn » Tue Jan 24, 2012 11:34 pm
Thanks mnemonic, I will probably stick with the auto if the new box [ actually 17k miles second hand box ] is ok. cheers, John.
AussieJohn
Re: Auto problem!
Postby AussieJohn » Wed Jan 25, 2012 12:37 pm
Right guys, I am really pi**ed off, with a new low mileage gearbox I still have the same problem, maybe transmission ecu? getting desperate now, cheers, John.
AussieJohn
Re: Auto problem!
Postby thedupleman » Wed Jan 25, 2012 1:10 pm
Could be.needsplugging in by sound of it
thedupleman
Re: Auto problem!
Postby AussieJohn » Wed Jan 25, 2012 9:26 pm
Booked in with Hyundai in Hessle for diagnostics on Friday, I'll post the results, cheers guys!
AussieJohn
Re: Auto problem!
Postby AussieJohn » Fri Jan 27, 2012 9:55 pm
Had it plugged in; no faults showing but still faulty. They suggested that I change both input and output sensors but as these are both different ones that were with the new box then it may be a longshot; any thoughts "auto gurus"?
AussieJohn
Re: Auto problem!
Postby mnemonic » Fri Jan 27, 2012 11:00 pm
It'll be a sensor fault then, somewhere - I'll do some internet searching in the morning and see what I can turn up... ;)
mnemonic
Re: Auto problem!
Postby AussieJohn » Sat Jan 28, 2012 6:42 am
Thanks nmemonic, the dealer said a modified end case with a different O ring setup could be a cure but other dealers had noted it didn't work for them. An auto transmission rebuilder in Scotland [ who is now the official Hyundai auto box rebuilder ] couldn't see how the different end case could affect this problem, it seems a can of worms with no definate answer. I am going to clean all the wiring plugs/sockets to the sensors today as the man who changed the box said he noted some corrosion on some bits [ would have been a lot easier if he had rung me while the box was out! ] cheers, John.
AussieJohn
Re: Auto problem!
Postby AussieJohn » Fri Feb 03, 2012 11:48 pm
Been to see Ross at Tiburon Automotive, what a helpful and knowledgeable bloke, he traced my fault to a solenoid not operating correctly, I've just got to figure out why, the main dealer is not on the same level as Tiburon, cheers, John.
AussieJohn
Re: Auto problem!
Postby AussieJohn » Mon Feb 13, 2012 8:21 pm
Checked all my wiring; metered ok, changing the ecu in a couple of days, hope I have a cure. [ engine and transmission ecu's in one box, bu**er ].
AussieJohn
Re: Auto problem!
Postby mnemonic » Mon Feb 13, 2012 9:18 pm
Hope it sorts it for you mate, keep us posted...
mnemonic
Users browsing this forum: No registered users and 2 guests
Share The UKHCC
