Chapp wrote:if it is cranking, remove one lead and plug, ground the plug out on a manifold and check to see if it is actually firing.
CPS failure maybe?
Chapp wrote:just one needed, I usually use bank 1, you will need a second person though unless you can see through a bonnet.
Users browsing this forum: No registered users and 1 guest
