by Rgray99c » Sun Feb 19, 2012 3:50 pm
So went to check air con yesterday and it wasnt working, by that i mean no colder air coming from it when airt con is turned on. Ive checked the compressor and its not turning with the engine, so i found the relay for it and "hotwired it" sure enough the compressor started turning, still no cold air, but ive checked everything electrically and seems ok. There anything else i can check before taking it to stealers, i used to have a hose which i could check pressure with, but that has since dissapeared since i "modified it" for my last car. There any sensors or anything that i can test first? cheers.
